Results 1 to 10 of 42
Thread: MR replacement motion sensors
    Default MR replacement motion sensors
    anybody have a source?
    The motion or the clash?
    The motion is on the board the clash is on the board of some models and others its on the positive leads
    Reaganomics not Obamanomics
    motion
    hummmmm....
    not sure about this one
    Anyone got an idea?
    The Part number is SW-18020P It is a spring vibration switch.
    They are available in HUGE quantities. The smallest being 200 Units (1 unit is a 1 Kilogram BAG FULL...That's a lot of them!) From overseas distributors. Mostly out of Hong Kong, and the United Arab Emirates.
    You can find these sensors in kids shoes (The kind that light up and flash), but the sensors are soldered to a controller board that is dipped in acrylic, and extremely difficult to remove without destroying the sensor. I have only been able to remove a small handful successfully, and only half of them worked right.
    There are similar vibration switches that are available in those flashing bouncy balls that you get out of novelty machines and dollar stores. They are of a bit different design but can be made to work. I'll post pics in a little while of the ones I am referring to.
    Mar 2007
    San Jose / San Francisco, CA
    4,082
    Exactly. These are essentially springs that (when sprung/springing???) complete a circuit, or open a circuit when the spring comes into contact with a metal ring around it.
    As you probably know, you could construct your own pretty easily if you had to do so.
    i had tore apart a old luke V2 style toy saber and it had that lil spring on a pole thing in there. something similar to what your talkin about.
    Lan-Ed-Tul
    The Brotherhood Of The Sith
    SL 6208 501st legion & SLD
    TK-6208
    Proud member of the FSM!!
    Mar 2007
    4,082
    Exactly. They are patented by some dude/company called "Yusan" for the mostpart. Yusan vibration sensor. Pretty useful I'd guess, but nothing more than a spring.
    Difference between a spring sensor and an accelerometer is basically digital vs. analog.
    Spring sensor is either 0 or 1, on or off...
    Accel sensor can have a whole myriad of feedback--a range. More analog.
    would it be possible to replace the stock motion sensor on a FX Vader with a accelerometer? i'm not digging the tilt sensors
