Results 21 to 30 of 49
Thread: My ongoing mhs project.
  1. #21
    Nov 2006
    Nebraska
    2,328
    Man i'm getting good at that drilling stuff.
    BLUE 3- Ready
  2. #22
    ya better be by now.
    Reaganomics not Obamanomics
  3. #23
    Well folks I need some help here. I need some ideas for accents on my plate. All I got so far is an accent led and the lever of my sliding switch.
    Anyone got ideas as to how I could make it look less bleak?
    BTW I drilled about 15 holes onder the plate for sound. I hope it works well cause I would be really pissed if I have a part that looks like swiss cheese.
  4. #24
    Hey, some of us like swiss cheese....
  5. #25
    Well I did some alteration to the activation plate. I drilled holes in the top and bottem then I took the other half of the plate and cut it down for an overlay plate to hide the mistakes of the plate switch hole.
    I only marked the holes and such will work on it more when I got a more steady hand.
  6. #26
    WOOHOO!!!!!
    Got my crown emitter. THANKS TIM!
    I cleaned up the crown edges a bit and It dosent fit quite like I wanted. I imagen that if my bladeholder was unsanded it owuld fit perfectly. so Iam gonn ahave my brother lathe down my bladeholder a bit to make it fit snug as a bug in a rug.
    Not sure when that will happen but Iam freanen happy that I am so close to haveing this finished.
    I need to work on my plates a bit more still.
  7. #27
    Well my brother has about 70% of the saber wired up.
    So tomorrow the rest of the wiring hopefully, then to figure out where to place my speaker and how to keep it there.
    I got to finish up my plates. which at this point is annoying me. so I hope this setup will turn out the way I hopted it will.
    Still trying to find an reflective film idea for my blade tip.
  8. #28
    Why not use one of the adhesive discs sold here. They look good to me. If not then mabey some time of renolds wrap type reflective material.
    Gold 2 standing by.
  9. #29
    He wants his blade tip to light up, or at least glow. Using the reflective discs blocks light to the tip, leaving it dark.
    You don't have a stricker sheet or some type of labels (adress labels or stamps) with that wax paper backing on them? It works, that's what I've been using.
  10. #30
    okay I must've read wrong.
    Gold 2 standing by.
