So Ive had an mhs saber for a while now.
Pritty basic. well almost all the basic parts.
But i went with this design cause in the tcss store page theres a pic of different changing sabers well theres one that has an overlay on it I was gonna do that but changed my mind, when I seen this I knew I had to get a lighttech crown emitter.
But sence lightech isent alive on the otherside of the site I have to hold off for a while till I can have one custome made for me.
So I had my bro do this for me at his work.
It was the style 5 pommel I had my bro shave it down on the lath and had a 05 vader speaker grill altered and shoved in there.
It still retains some of the rounded ness but Iam gonna sand on it more and make it more pronounced.
Now all its got is a 3W cyan bin 2, with a 33" tcss blade ran on an 05 vader sound board.
I have ordered some parts and sadly I wasent abel to get the LT emitter but thats all I am missing.
My 7" plain style 1 hilt section is being lathed on for some light grooving. hopefully its finished today so I can put this togeather cause hopefully the parts will come in today. Just need to find out when my extra shock sensor is susposed to get here.
Iam gonna be running the 3w cyan for now till tim can get the k2 cyans in, Iam gonna go from 80 lumens to 130 lumens. ;D
Iam gonna use the mr board for sound only and its gonna have an accent led driven off of with the proper resistor so I can plug it with almost 5 watts.
Iam gonna be using corbins latching driver thanks to Xwing for that and the altering he did to it already. He soldered leads to it and shafed it down to fit the mhs. Again Thanks Xwing.
I Got me a rotory DPDT switch to make this possable.
Now I am setting this up for rechargable so in a recharge port goes.
Iam flipping my 7" hilt section around so the origional button hole is now for the recharge port and allows me to have a resinance chamber of sort for my speaker.
I went with the 4.8V AA rechargable battery pack, 2.1MM plug and jack. the pluc has the correct connector on it so its a plug and play for my nimh battery recharger.
Now sence Iam doing this setup I need another clash sensor, and thanks to corbin that will be possable to run this properly.
So iam gonna have to drill a couple holes in my ribbed section for the switch and hopefully it will fit or iam gonna have to reses the hole which I dont really want to do at this time. cause with just a hand drill thats gonna be tough.
So Thats about it for the build up of it with the purchased parts. I have purchased a sinktube a longtime ago that I can now make use of to make a style-ish activation plate of sorts.
Iamnot sure what iam gonna do for say the looks like painting or whatever I dont know yet.
But I am gonna do some damage to it to make it look like it fell of a cliff of sorts and some weathering that I think will work. Not the kind of it being aged but in use but like its seen alot of battles and Iam gonna use alot of 0000 gritt steel wool on it in places.It will change the aluminum look to that of gun metal gray.
Iam gonna use it in places then even it out to look like it aged in thoes places that dont get used much.
Then Iam gonna smoth out places where hand location would of been for its many battles.
I will then be rewrighting my story I made. Its not like a short story its more of a long story from hell, almost book.
It will tail how my charater came about and how he found his first lightsaber that turned out to his own from a previous life time.
Enjoy and expect pics to b up in a couple days.
Ok so my picture taking skills arnt the greatest of this camera isent the greatest.
So here it goes.
It looked better on the camera so just bear with me here. at least you can see that theres grooving into it. the 2 on the beginning and ends are wider but on one side its like it wasent cut deep enought but I dont know how that turned up.
But at closer feel they all are like that. kinda like it had a wobbel into it but thats ok. Not to big a fan on perfection when it comes to something of this...size.
Becides I may put a grip plate there I dont know.
Iam not gonna clean it up at all after I start constructing this thing so if theres a mistake like the drill bit walks then thats gonna stay there.
But on to do some test fitting of board placements.
