So the next thing I decided to do with this one was to modify the original "clicky" switch to include a momentary....yes, I know it's not necessary with a CF but I might want to swap it out someday for an Ultrasound and then I'd have a switch all ready for it. So, I used my hobby knife to and a small flat screwdriver to pry it apart:
Here's all the pices:
I won't be using the spring, so I'll set that aside....first thing to do is to hollow out the bottom of the swich housing:
Next, I took the white piece of the switch plunger assembly, and using my cutting pliers, snipped off the cap-end:
This will allow the metal piece to go all the way up into the plunger, leaving a bit more room for the tactile switch's button.
