Well,
Several of you may be familiar with my Malius saber. It was the first major weathering job I did. Like the Killer Penny saber, this one is also brass and copper. It also uses the same grip material. In fact, the whole reason the KP got made was the Malius saber had gotten its grip section screwed up by a guy that was supposed to be brazing a threaded plate onto it for me. He got lazy and blasted several holes through through the piece. If that hadn't happened, I wouldn't have searched for another grip section so hard. When I finally found it, I had repaired the original piece enough to be used....so I had a spare.
Here's the original weathering job on the Malius. This is EXTREME weathering though. Meant more for a display piece than something you'd carry around. Think museum artifact:
This look was achieved by dark (almost black) lacquer that was thinned down and sprayed onto the piece. I then used a pencil torch to scorch the surface of the lacquer in a few places. Not quite to where it would bubble, but almost. Then I used a Scotchbrite pad and lightly scuffed up the areas, removing some of the scorched lacquer. Where I wanted it to be more "clean", I just didn't spray it, or I'd mist it from like 4 feet away.
Around the activation box, I used pig manure (strong with amonia) and left it on the piece for a couple days. This corroded the brass quite well. During these two days, the saber was burried in my back yard too.
Here's the grip section that was almost destroyed:
After handling, much of the weathering wore off and here's what it looks like now:
Corbin
