In all fairness Dan, I wasn't posting facts about anything that the scientific community doesn't know for certain. If you travel through time and not space, you will end up exactly where you started, but since the earth will continue moving during the time that you have skipped you will end up in the vacuum of space. This is not merely a theory. I could demonstrate the same principal using a train, or for that matter a bargraph. It has nothing to do with quantum physics, only with simple geometric observations. As for what Pockets has said, he's not merely talking about untestable hypothesis either. What he said does make a few presumptions about how wormholes work (presumptions which are supported by some in the scientific field, I might add) but he is still stating something that is fairly obvious. Humans aren't cut out for traveling in conditions considerably hotter or colder than room temperature, we can only survive at pressures approximating those on the surface of the earth, and high speeds will, as he pointed out, peel our skin clean off. It isn't much of a stretch to assume then that a hole in the fabric of reality might be a less hospitable place than, say, death valley antarctica or the line at the DMV. Do not assume that intelligent people cannot make intelligent observations about a phenomenon simply because they have never seen it.
And also, religion and philosophy have nothing to do with it.
Do I seem grumpy tonight? The wait for the new MHS pieces must be taking its toll... Cheers!
