i'm pretty sure. corbin could probably confirm this
I'd just get another Y-Splitter and plug it in... lol
I think it's supposed to be wired in Parallel with and before the Sound Board (if so equipped).
IF I understand correctly ..............body edited for stupidity's sake (Mine )
All things a beginning have.
As all things do an ending.
Be not too hasty from one to the other to move, or much will you miss, along the way.
No! Put it AFTER the switch, or it will always be on. Did you look at LM's simple diagram?!
This Jedi Ranger has a name....Terek Kelrune. Don't forget it.
no I didn't really. Thanks. it does make sense AFTER the switch, probably what I meant to say...its been one of those days.Originally Posted by Jedi Ranger
weeks actually.........
tenric, why didn't ya?
i put it there for a reason. lol
simple assumption problem........looked like what I had seen before.
then I forgot the whole issue of why a switch was there......just had a "blonde" moment...forgive me
So one wire on a switch wire and the other on the pos side of the batery pack?
Reaganomics not Obamanomics
Hi guys! Sorry to bump an old thread, but I was wondering if I could get a definitive answer about the best way to wire Corbin's PLI to a saber using a sound card (MR sound card or Ultra). I purchased one and want to get more for my other sabers but I want to make sure I wire this thing correctly. I assume you already use the wires provided, should I cut off the connector? Anyway, any help would be great! Thanks guys!
Unless you are using the J-plugs just cut it off.
PLI's are dead simple. Just put each of the wires to the respective battery leads... then interrupt the loop with a momentary switch (or latching if you prefer).
RED LEADER Standing by!
