I wired up my saber with a Luke sound board I had lying round. Now its making wierd noses and doing other wierd things. I made a vid, whats wrong?
http://s45.photobucket.com/albums/f5...t=CLIP0056.flv
Blue 4 "Im hit!"
tell me what your setup is and we'll see where your problem is coming from.
one thing im noticing is when you activate the mr its playing the clash sound rather than the power up and idle. i have had this same problem a few times when using a push on push off switch in place of the momentary that comes with the luke module you will lose either the power up or power down font. the strange thing is when you hit the shock i heard the power up sound font.
try taking the clash sensor off the card and see if you still have the problem, from the looks of it im leaning towards a bad sensor.
let me know what happens...
i had a mace that did that when the relay stopped working right. I also had one that did that when the clash senser went bad
BLUE 3- Ready
I jsut checked it out snd its not the clash sensor. In this vid I do it with the switch connected to the battery not to the switch wires, and start with out sensor, then at about 1:05 I plug it back in, then at 1:16 I unplug the led, then at 2:20 unplug the sensor. WHats going on?
Blue 4 "Im hit!"
thats the problem, your switch is in the battery route and not on the board... take the switch off the battery lead and back on the purple wires and everything should jive...
had the same problem on the 5w with mr setup when i had to use 2 switches or i would lose the power down font. try what i sugjested and let me know if it clears up the problem...
The only reason I had switche dit was because you said that it might have been because its a different switch. Dont know what to do know.
Blue 4 "Im hit!"
Are you sure? Im still working on this, if anyone has any idea whats wrong please help.
Blue 4 "Im hit!"
Try the switch on the boards switch leads if it works find then theres your problem.
I have. It still messes up.
Blue 4 "Im hit!"
