Results 1 to 3 of 3
Thread: Of Sleeves Blade Holders
    Default Of Sleeves Blade Holders
    Hi, I'm working on designing my first saber and would really like to modify an emitter/blade holder so that the tip is shrouded. Does anyone know which blade holders will fit inside the MHSSL2-18 Sleeve?
    Jul 2012
    575
    I'm not entirely sure if this answers your question, but the MHS Sleeve material will fit over standard MHS parts with a 1.45" outer dimension (and sometimes a tiny bit more). The Description of the BH's will tell you what the max OD is if it is wider than 1.45" OD.
    Your reply actually did help! Thanks for clearing that up for me.
