I'm making a saber with a rechargable battery. what resistor and battery should i use?
You can try to fight the man(a.k.a. The jedi staring at you from across the room) But I bet you'll lose.
I saw you posted this over on another thread too. The resistor you need will depend greatly on what LED you're using and what battery pack you're using. Go here:
resistor chart
You really should read through the forum first before asking questions. The information you want is already there.
I notice from your other thread you havent decided on a design for a sabre yet. Well do that first as that determines what size battery you can fit in. Once you know that and youve decided on the led you want to use you can then decide if you want to use a resistor (and what value it should be) or use a driver (buckpuck etc).
As I said all the info is contained in threads already. Try doing some research first.
Phil Higgins
I've decided on saber just thought i might add some things. I saw the resistor chart before but i couldn't find it again
