Results 1 to 4 of 4
Thread: Long absence from saber building, need some advice.
    Default Long absence from saber building, need some advice.
    Hi all, its been a really really looooong time since I was last here. (Like 10 years, as you can probably tell from my avatar and sig,)
    Anyway, SW Celebration is happening in my backyard this year, so I figured I should probably get my sabers up and running. Ive been digging up all my old saber gear, as it was scattered in strange hiding places, stashed away throughout my apartment. It looks like I got a bunch of stuff to work with, but it all has to be rewired, cuz it was stored haphazardly and all the electrical tape like rotted off. So some of the connections broke.
    Anyway, I think Id like to replace the Lux 3 LEDs I have with some of the newer brighter ones, but Im not sure what else I would need to make the new ones compatible.
    My current setup uses an MR sound board, but I think I will leave that out of this build as sound will not be important at the Con. I was thinking of doing just a simple set up of LED->Resistor->4AAA battery pack->Switch
    My question is, if I want a super bright Sithy Red LED, and super bright cool Blue LED, 1: will the 4AAA battery pack be sufficient? and 2: which of the LED models should I get and with which resistor (the one I currently have is 5W)?
    Thanks all!
    RED 7 Standing by...
    Many of us are running the Tri-Crees sold at TCSS with a 3.7 Li Ion battery. As far as which resistor, it depends upon which color LED you choose, and what your supply voltage will be. TCSS lists all the FV and current needed to drive the LEDs. Also, on the store's main page, there is a LED calculator that can come up with the closest resistor that TCSS sells for your cree and power supply.
    Tom
    "Let the past die."
    Quote Originally Posted by SilentBob501 View Post
    Thanks all!
    No, 4AAA’s won’t cut it these days. You would need to run a Tri-Cree with a 3.7V li-ion battery setup. The resistors you need depends on which color you want. I have a tutorial floating around here somewhere that shows you how to do the calculations.
    Hey guys, thanks for the responses. Id love to upgrade to a tri-cree, but I think I would need a whole new setup, and that would probably end up being around the cost of a whole new saber. So if I just wanted to upgrade from my Lux3, could I use my old set up and simply swap out for a more powerful LED? If so, which one would you recommend?
    Thanks all!
