Results 1 to 9 of 9
Thread: Anakin 05 with Green Blade
    Default Anakin 05 with Green Blade
    Greetings. I am new to the forum. I want to convert an Anakin Ep III Lightsaber to have a Green blade, but with a led strip. So, I was thinking of buying a Luke Ep VI Lightsaber and removing the Green blade and fit it to the Anakin one. Also, I do not know if it is possible, to aquire the same type of led strip that Anakin's lightsaber has, just green. If there is any way to make this conversion, I would gladly appreciate any help. I am familiar with electronics and I know how to use a soldering tool if needed. The reason I am doing this, is because I simply like the Anakin's hilt and completelly dislike Luke's...
    Better not forget things in the fridge...
    Oct 2005
    3,521
    Its possible but the wiring is a little different between the 2 models.
    Is then possible to simply change the blue leds on the strip to green?
    Oct 2005
    3,521
    That wouldnt worth the time. Would be easier to get a green led blade and wire it to work in your hilt.
    May I ask for your help then, if you can, to post some schematics so I may rewire the blade? I would greatly appreciate it.
    Oct 2005
    3,521
    If you get a green led strip and then take yours apart the differences will be noticeable and should be easily worked around.
    OK, last question then. Is it possible to aquire a plain green led strip, or it can only be found within Luke's saber?
    Oct 2005
    3,521
    E-mail me.
    Done. Thanks.
