I will have a mix of the following types of batteries for different hilts:
http://www.thecustomsabershop.com/Pa...tery-P853.aspx
http://www.thecustomsabershop.com/Pa...ery-P1282.aspx
Can I safely switch between the 1amp Battery charger http://www.thecustomsabershop.com/37...ger-P1180.aspx and the 500mAh battery charger http://www.thecustomsabershop.com/37...rger-P129.aspx that TCSS sells? For Example say I used the 500mAh charger before an event to charge the battery and once the battery runs out I use the 1 amp charger to recharge. Is this safe to do for both types of batteries?
Thanks in advance
