That should be fine, you'll just have a pretty darn scratched piece at the end. Gotta polish all over again. Honestly, whatever you used when polishing that took off that little bit before would also work, if it was polishing compound on the Dremel it just might take longer. But taking a long time to do a nicer job is probably the best way to go. I weather my sabers a lot so a perfect finish isn't really my forte.
Edit: is that 400 grit paper for wood or metal? You might want to pick up some 1000 grit wetdry. Just to be safe.
