Ha! I'm so stupid! Thanks Greenie.
No dude, just young. It’s an old fashioned saying/phrase. I’m old
Wow! Polish works grrreeaaat! Very shiny! The pics don't do justice.
Until I was removing scratches from the shroud. I was happily sanding away until I noticed that there seems to be an extra coating, wich I only sanded away at one spot.
What can I do about that? Do I have to make a new shroud?
You don't have to make a new shroud. All tcss sleeve material has that finish/coating. You just need to carefully sand off the rest of it and repolish. No biggie.
Edit: when I'm grinding off that coating I use a mouse sander with fine sandpaper so it has a nice flat plane and takes off very little metal at once. You don't want to breathe that metal powder, so be safe. A belt sander might work for that too.
Edit#2: I use my mouse sander because I don't have a lathe, but that may be easier because that will preserve the "grain" of the metal, ya know? Nice and uniform spun finish.
Those polished pieces look great. Good luck with your shroud!
Player: I feel your anger, master.
Darth Baras: A blind, deaf, comatose, lobotomy patient could feel MY ANGER!!
Whew! That's a relief. Thanks Vereous. Might I ask what grit of sandpaper do you use for that?
Got a second question you guys. After I polished my saber, I noticed as soon as I touch or handle my saber it leaves marks and finger prints. How can I keep my saber clean and shiny after polishing?
Applying a clear coat will help, but you're gonna get visible fingerprints on a highly polished saber. No way that I've seen to eliminate that.
Oh well, geuse I'll just rub it with a moist microfiber cloth each time after use. Wearing gloves while dueling with my saber should also help, gloves will be part of my costume anyways.
Edit: would 400 grit sand paper work? That's the finest I've got.
