Board Lurker
Converting MR .45 scale lightsabers
I was wondering if anyone has any experience or information about converting the Master Replicas .45 scale lightsabers for light. (I assume there aren't any sound boards that can fit in them.)
Specifically I am interested in installing a 5mW, 3-5v laser (like this one) into a Luke ANH Graflex to turn it into a laser pointer. It seems like there should be just about enough space in the hilt for the laser module and a AAA battery with a small gap for switch/wires but I'm not even sure how to go about disassembling it without damaging it.
The only guides I've been able to find online are for completely stripping them out, including the emitter ring, glass eye, and red button, to turn them into vape pens, and I was hoping to keep it a little more intact and screen accurate, ideally with battery access through the pommel.
Not knowing the internal dimensions, i cant comment on the sound card, but finding a decent enough speaker would be my worry lol. It looks like you might fit an 18500 and an LED in there, not sure about a switch though.
Board Lurker
Yeah I really doubt there's hardware available, or space inside for sound, but I thought I'd throw it out there in case anyone had managed it before.
As for the ID, I'm not sure if there's other stuff inside that would get in the way, but at the emitter end the ID is a hair over 15mm, and from the pommel to the bottom edge of the emitter curve it's 104mm long, meaning there would be about a 20mm gap between a AAA and the laser module. There are also even smaller laser modules available, but I was hoping to use one with a line or cross pattern since those really drive my cats nuts!
For the switch I was hoping to attach it to the clamp card, but the gap between the ends of the clamp is tiny, and there appears to be a bit of plastic in there holding them apart. But I'm thinking it might be enough space for a momentary switch post, or maybe even a latching switch if I grind out a space for it.
Reason: spelling
Board Lurker
