Results 1 to 4 of 4
Thread: Recharge port question.
    Default Recharge port question.
    Ok does anyone know the size of the 3 solder blades on the 2.1mm recharge port sold in store. I want to use slide on connectore to make installation of the port in the hilt easier. Took me forever to screw it into the threaded hole in my 4in extension. And when i finally got it in i realized it was broken. So i have decided to find a waybto screw it in and then connect the wires to it. I found some small slide on connectors that will work perfectly but i dont know what size to buy as i dont know the size of the 3 blade/pins that stick out of the bottom. I would measure mine but i have cut and soldered to them to much to be able to measure them accurately. So someone please help me.
    I measured and it’s about 5.25 mm or .2050 of an inch.
    If you haven't found them, there are angled variants of those connectors that may be helpful.
    I dont know that there is enough room to use crimp connectors and why would you want to? That creates another joint that can fail.
