Results 1 to 4 of 4
Thread: Prizm v5.1 single 18650 3.7v RGB resistor values
    Default Prizm v5.1 single 18650 3.7v RGB resistor values
    Hey guys,
    I just needed some quick help with which resistors I’ll need for my main LEDs
    Using R/G/Rb Tri-Cree
    Green Cree Part# XPEBGR-L1-0000-00G01
    130 Minimum Luminous Flux @ 350mA
    Forward Voltage @1000mA = 3.7
    Red Cree Part# XPEBRD-L1-0000-00901
    80.6 Minimum Luminous Flux @ 350mA
    Forward Voltage @1000mA = 2.65v
    Royal Blue Cree Part# XPEBRY-L1-0000-00S01
    650mW Minimum Radiant Flux @ 350mA
    Forward Voltage @1000mA = 3.4v
    or try this: Resistor Calculator for Dummies Like Me Fill in the blank.
    You'll learn that greens barely need a resistor, if at all, blues you'll want something small, reds will be larger. I know which ones from the shop I use for each color, but you'd best learn for yourself. Or, look to see where it's been answered a dozen times before.
