ROTJ LED Wiring question
I saw the picture posted here for the wire descriptions on a MR Luke ROTJ sound board. It also mentioned not to hook uo the LED on the same leads labeled in the pic. My question is where do you hook up the LED then? Would it be possible to use a K2 instead of a Lux III? Would it also be possible to hook up one of Corbin's PLI on the board as well? Sorry for all the questions but I'm new. Any help would be greatly appreciated.
This is the link with the wire description:
http://www.thecustomsabershop.com/fo...pic.php?t=1067
ROTJ Wiring Question
Thanks for the quick response, I just wanted to double check before I did anything. I did get a wiring diagram on how to run a K2 off of the sound board but as for the PLI I knew that it was a splice in. I am unsure though what wires I should solder it to. Do you know by any chance?
So then if I undestand this properly, the PLI would get spliced in on the wires coming from the switch?
I was messing around with the wiring on the PLI and I've also got it to work my connecting it to the pos & neg leads on the LED. Is one way of connecting it better than the other? Sorry for all the questions but I'm only 14, have never done any of this, and am trying to do this as a surprise for my Uncle.
