Originally Posted by
supertrogdor
Hi bgonc, a momentary switch will only stay on when you press it. So if you wanted it to control your LED's on/off status, you would have to hold it in the on position with a finger for the entire time you wanted the LED to be in the on position. Converting it to a Latching swith is probably your best choice if it controls that facet of your saber. Some people use momentary switches with sound options, like the flash on clash effect you can get from some of the soundboards that are available, but i kind of doubt that you would be able to tuck that all too safely inside a joystick and still have room for batteries. Then again i shouldn't spout off too much, because i have no idea how big the joystick is.
cheers
