Originally Posted by
Tom Tilmon
So, most of these Protected Circuit Lithium Ion batteries have a "protected circuit" system on them. You can buy your own here at TCSS to make your own pack. The circuit is designed to trip at certain amps, spikes in discharges, or at a certain voltage (while charging). When I say trip, I mean the circuit takes the battery out of the loop when these events trigger the protection circuit to do so. That is what makes these batteries considered "protected circuit".
So, I think your saber blades are tripping the circuit on your battery, because as soon as the strips start lighting up, your board re-boots. This is a pretty solid giveaway that your battery tripped. Are you using the 5 amp or 10 amp protected circuit battery? If you're using the former, change over to TCSS new 10 amp protected circuit. That should solve the issue for you.
Tom
