TCSS Parts List:
1 of: MHSV1 Blade Holder Style 12 w/led module and heat sink
1 of: Panasonic Li-Ion 18650 3.7V 10A 3200mAh PCB Protected Rechargeable Battery
1 of: Acrylic Chassis Disc for Recharge Port - S8 (Clear)
1 of: MHS speaker mount V4 - For 28mm Speakers
1 of: MPS Clip
1 of: Chassis Disc style 5
1 of: Hilt Style 5 (7" Fluted double female threaded connector)
1 of: Gender Changer
1 of: 2" Double Female
1 of: MPS Pommel style 4
1 of: MPS Insert style 1
2 of: Switch 22
1 of: 2.1 mm switchcraft recharge port
1 of: brass covertec wheel and screw
1 of: tri-cree lens
various lengths of tube in blue and brass for chassis
Sourced elsewhere:
S2R3 (NEC)
NeCree (NEC)
Railmaster 28 mm speaker (NEC)
5mm RGB Common Anode LED (NEC)
5 mm accent LED's (red, green, and blue) had on hand
Leather wrap: had on hand
Quartz point: had on hand
Parts:
Switch plan (originally tried to squeeze them in to 1.2 double female by butchering heat sink. This failed, had to expand to 2" double female to make this work. Still pondering how to better accomplish this, keeping switches as high as possible without adding extra hilt pieces to do so.
Chassis brainstorm:
Bench Test Fire:
Final chassis assembly. There are 3 5mm accent leds in aftmost ring on RC Port. Red, Green, Blue which are on programmed cycles (Ide, Activation, Hum, Clash, Blaster):
Put the non-fluted end down, fluted end of hit up. Cut out 4 vents with dremel to expose crystal chamber (and vent more sound). Leather wrapped the bottom of hilt, the smoothe part, and put brass covertec there.
Demo Video:
I learned a lot building this one, and I already know that Stephanie really loves it. So did everyone else at work that saw it. Its a bright and loud saber with a lot of cool features.
Tom
