Ok, from the led in the hilt, + terminal. Run a very thin piece of copper wire. The wire goes to the end of the blade where a small, 1/8 inch, metal cylinder is. Wrap the wire around the cylinder as much as possible. Then run the wire back down the blade to the negative terminal of the led. Yes, gravity would make the sphere go "up". This is my idea, most likely impossible.
