Results 1 to 6 of 6
Thread: Dark Jedi Miklan Welown and Apprentice Gabard Welown‘s Fyra sabers
    Default Dark Jedi Miklan Welown and Apprentice Gabard Welown‘s Fyra sabers
    So I recently picked up 2 Ultrasabers stunt sabers, the Aeon V4 and the Apprentice V4, for my 6 year old and myself. After getting them and going to the park to “duel” on the wooden playground equipment. My 6 year old asks me, “how can we put sound into these sabers?” I guess he was embarrassed with making lightsaber noises.
    Anyway I also picked up 2 Hasbro Blade Builders sabers from Target and split them in half to get the sound boards. I glued them back together and now we just have cheap plastic toy lightsabers.
    I then started watching all the YouTube videos I could find on installing soundcards. Rob Petkau’s videos were great, and Odin’s video from Odin Makes was very helpful. After rewatching and rewatching I felt confident enough that I started ordering all my parts.
    From TCSS:
    16mm Anti Vandal Momentary Stainless Switch
    MPS Insert style 7
    MPS Clip
    BuckPuck 1000mA 4-wire
    JST Extension Green 26 AWG
    1/8" Heatshrink tubing
    MPS Pommel style 6
    From Hasbro:
    Blade Builders Saber sound card
    Stock speaker
    From US:
    Existing Led module and 4aaa battery pack from the Aeon and Apprentice
    From Saberforge:
    Red Day Blade
    The build went really well. I have more wire in them than I need and will go in and clean that up later. I ended up using 4 different saber parts suppliers for our sabers. Hence the name fyra saber. Fyra is four in Swedish and I have a lot of Swedish ancestors on my maternal grandmother’s side. Anyway they are complete and here they are:
    Parenthood winning! For a 15$ soundboard, not bad. Now you and your son don't have to make your own sound effects! WTG! Winning parenthood, out fighting with sabers at the park. That is awesome.
    Awesome!
    I noticed the diagram in the back, would you mind posting it? I haven't seen a buckpuck working with a econo bladebuilders board.
    If you hook the speaker negative to a tip42c and feed that to your LED, you can get a nice flicker effect in the blade.
    You might be able to use a tri-cree with 2 die on the buckpuck and one flickering die on the tip42c/speaker negative.
    Once you have these figured out, you can be confident a pro board install will go smooth.
    Quote Originally Posted by Whosle View Post
    I got the idea from this video:
    Would I be able to jumper the LED- to the Battery- on the board?
    You might be able to use a tri-cree with 2 die on the buckpuck and one flickering die on the tip42c/speaker negative. Once you have these figured out, you can be confident a pro board install will go smooth.
    I can't wait to do that. I'm looking at the NB4 for our soundboard upgrades someday.
    Wow fast reply!
    Yes, but depending on your V threshold on the transistor (NTE) , sometimes the speaker signal overtakes the control and ends up dimmer. The brightest way is to have it on a seperate transistor, and have it feed the LED after switching takes place. A tricree makes this option better.
    Are you using just a single cell 18650 3.7v? If so what is the input voltage of your microbuck?
    I might revisit the bladebuilder cards now. I think I have 2 kicking around. They are surprisingly compact.
    You might be able to use a power extender (in the TCSS shop) as a replacement for the bulky transistors. That is my next attempt. Also thinking on putting a 5v stepup and 2watt amp. Lots of work for one soundfont ,though.
    The Nbv4 is a perfect start for you after these builds. No pads to clean up, larger through holes etc.
    Cheers!
    I'm using 4 aaa to whatever that equals. Yeah I monitor a machine all day at work and when things are running smoothly I have time to browse forums and reddit.
