Results 1 to 7 of 7
Thread: Think I Fubar'd my saber, opinions or ideas?
    Default Think I Fubar'd my saber, opinions or ideas?
    This is a problem I've had with this saber for quite a while, just never posted on it for some reason. So with my Vader saber, the swing sound was severely laggging behind the motion, so I had the bright idea to just clip off the motion sensors and keep all other sound.
    As most of you probably know, after a minute or so of inactivity, the MR sabers shut off.
    So now my saber shuts off after a minute every time. Unless I clash it against something. Which is fine for dueling, but crappy for everything else. Is there any way to fix this aside from buying a new card?
    Ryma Mara
    Guest
    Put the sensor back in. or try a new sensor
    If I still had the sensors... they got rather non functional in the extraction process
    I don't know if the MR sabers are much different, but the clash sensor on the Hasbro board is just a conductive tube with a contact suspended on a spring inside. You could probably build one for next to nothing.
    Or even buy one for next to nothing.
    Check on a few of the electronic supply sites.
    Mar 2007
    San Jose / San Francisco, CA
    4,082
    Indeed, they are basically just springs waiting to collide with another piece of metal in order to "detect" a collision. Digital motion sensing--on & off. Nothing super fancy.
    I can tell you that the shock sensor has a label of "Yusan" on it. Corbin also might know more. I know that he has clash sensors-- but not motion sensors as far as I know.
    Nov 2006
    Nebraska
    2,328
    here is what was on mine
    BLUE 3- Ready
