Results 1 to 3 of 3
Thread: Led tri cree problem with red
    Default Led tri cree problem with red
    Hello
    I have a Tri cree star led and I use the red and the royal blue,
    I have a nice purple put after 15 minutes my red dims
    And go's out I use the Nano biscotte and 1 li-ion battery
    Is it problem because I use 1 cell or what? Thanx
    The red would stay brighter longer than the blue as battery decreases, and you should only be using one cell.
    What resistors are you using? If you've under sized you might be burning out the LED.
    Hello I use 2.2 for the red
