Results 1 to 2 of 2
Thread: Prizm 3.5 4,5,6 fonts won't read
    Default Prizm 3.5 4,5,6 fonts won't read
    Having some problems getting my prizm 3.5 to recognize fonts 4-6. I have experience with these boards and know how to add fonts properly. This is one I had been holding on to for a while but everything functions fine except it only runs 3 fonts.
    After searching I found this but there was no resolution.
    http://forums.thecustomsabershop.com...zm-3-5-SD-card
    If you know anything, please help me out. Thanks.
    Btw yes, I formated the card, copied 1,2, and 3 exactly and renamed them, and I named the 4,5,6 fonts 1,2,3, to make sure they were not corrupt and they work. The board just doesn't recognize 4,5,6. I am also aware it's case sensitive.
    Did you do a quick format, or a full format? It makes a difference. Full format is required anytime you change the font files. Formatting is not required to change settings in the config files.
