Hello, just finishing a couple of new builds, one an old minicam with a MHS adapter and mount, the second still finishing electronics wise, a K4....I was working out some different ways to mount the blade in the MHS mount without a retention screw, thought it would mess with the asthetics, and came up with a method that has worked really well, even in the hands of my 10 yr, and believe me, the kid can tear up a rock in 5 seconds, this has probably been done a million times but I thought I would share it anyway, I have a good one inch depth of blade in mount and wrapped just one layer of pipe tape 3/4" up blade and screwed into mount same direction as tape applied, very very solid fit with no movement even with dueling, and can be quickly removed with no tools, hope its helpful for others looking for similar solution. probably need to be redone after a couple of uses, but cheap and easy.
