This is a little method I use for drilling and cutting complex designs on cylindrical things like sleeves, shrouds, etc... without expensive layout tools. Well, maybe the computer and software are expensive.
I am sure others do it as well but I thought it would be good to have a dedicated post for it.
I figure out my circumference and height, then draw a rectangle to layout my boundaries. Next, I layout my drill holes and cuts where I want them and label with the drill I want to use. Next, I print the design and apply spray mount to the back of the design. I mark where to line up the paper on my workpiece and adhere the layout.
When done, you can remove the layout with oil (not the best), acetone, Goo Gone, or soaking it in heavy duty cleaner.
For this particular design I had to have holes, slots and cut outs line up with preexisting etching and plating. When I designed the layout i designed it as a third layer on top of the layouts for the etching and plating. The method works very well. Notice in the 2nd and 3rd pics how the little holes line up near perfectly with the pre-etched lines.
