Can any chassis parts be used for the NBv3 MWS? Are there any ideas being able to get one made for it?
Any of the chassis discs for the NBv3 should work with the MWS, it's just be a matter of putting the sound board in the right direction. I would imagine with the MWS in place, you'd have to slide the disc on from the SD card slot end & up to where the MWS is wired in place.
From reading the description it states that it's not compatible with the NBv3 MWS version though I think I'll try it anyways
I had to trim the corners off the NBv2 MWS to use the chassis discs. I wonder if similar modification is what is needed.
Once I can afford it, I'll try it, so much work to make a dream a reality so worth it in the end
