Hello can anyone recommend good li-ion 18650 battery and charger
For charger I can get enerdan, voltcraft and niticore from alliexpres
Does it matter that the battery 3400 mah or 2600?
Thanks
Thanks
The attached store sells these things so we will not recommend other products from other vendors as that is against the rules of this forum.
In the matter of 3400mah vs 2600mah. The larger the number the longer the runtime. So a 3400 mah battery should last longer than a 2600mah battery under the same load.
Panasonic makes good batteries.
If you don't get a good suggestion here, Plecter Labs may be able to offer advice. They are based just South of Paris, so may have access to many of the same brands/stores as you do.
panasonic i can get this
good, plecter labs i whil contact them
thanx
