Results 1 to 10 of 11
Thread: LED question.
    Default LED question.
    I just had a quick question about the led's in the store. Will there ever be an option for a custom tri rebel LED? I would really like to run a deep red rebel with a white FOC in my saber but I don't know if that's possible since there is no custom tri rebel option. Or does Cree make a deep red that is not currently offered by tcss?
    BEING DARK DOSEN'T MAKE YOU EVIL JUST... MISUNDERSTOOD
    What are you looking for? The Tri-Rebel has an RGB & GGW. RGB will pretty much cover just about every color option you could want.
    Naasad Tal - A.K.A. Chris S.
    My Saber Build - http://forums.thecustomsabershop.com...from-MHS-parts
    Thank you for your reply nassad I'm looking to have a main blade color like the single die deep red luxeon which is more of a ruby red than the standard red dies with a white foc I would not know what color to mix with standard red to make it darker
    Not sure which colors would be best to mix together for a deeper red.
    Did you chose the Rebel for a reason? You might do better to look at the Tri-Cree XP-E2 line, there is a RRW option. The Tri-Cree also has a custom option, with several color options available.
    Here's the link to the RRW Tri-Cree:
    http://www.thecustomsabershop.com/Re...ova-P1014.aspx
    & here's the link to the custom Tri-Cree:
    http://www.thecustomsabershop.com/Cu...LED-P1035.aspx
    The only reason I chose luxeon is because I specifically want that deep red color if Cree has a die close to that color that Tim could feet I would more than happily by Cree because I knew everyone here prefers them.
    May 2015
    United States
    1,756
    2
    Looks like the only red variants are red, red orange, amber, and PC amber.
    Click "Variations" tab: http://www.cree.com/LED-Components-a...nal/XLamp-XPE2
    Right which is why I asked about the custom luxeon because there is a drop red variant on the single die rebels
    Not sure how true it is, but I was told the Rebels are slowly being phased out so you're likely not going to see more tri-rebel options.
    That's very good to know thank you so much
    Jedi Padawan
    Sith Adept
    Jedi Padawan
    Cire Yeldarb's Avatar
    May 2013
    United States
    595
    Quote Originally Posted by darkjedimaster07 View Post
    Just send an email to Tim and ask him if he'd be able to do that, maybe he can
