Tracking Down a Problem
Hey, everyone. A bunch of you helped me figure out a latching AV switch solution awhile back. Then I had to go and get fancy because the bulkiness of the wire splices bothered me. So I concocted this idea to use a circuit board with some copper strips. I figured attaching the different wires inline on the circuit board would do the trick. Everything is hooked up per the diagram below. Problem is, the switch doesn't function. It light up, but the main LED stays on as long as the battery is plugged in. I know I must be overlooking something, but I can't figure out what it is. Anyone have any ideas?
Just for reference, this is a lime-green Rebel with a 7.4LION battery pack. I have a dynaohm resistor wired into the switch.
Thanks!
