Results 1 to 10 of 16
Thread: Belt clip for d-ring?
    Ryma Mara
    Guest
    Default Belt clip for d-ring?
    How would one go about a belt clip for a d-ring and not have it ugly?
    I have heard of people using dogleash tingys but thats just ugly and gawdey(sp).
    I was thinking of taking 2 covertech clips and bolting them togeather and hang the dring on that but then I have no idea how well the saber will stay on there.
    What are your thoughts?
    5,899
    Those?
    RED LEADER Standing by!
    Ryma Mara
    Guest
    Intreting. about how long is it and where could one find such a thing?
    5,899
    They were specifically made for sabers. Without one in front of me I'd say they are 4" long. They're that long so that you can attach them in the center of a large jedi belt and still hang low.
    I'd have to dig up who I got them from, but I have 10 at home.
    Aug 2006
    Wandering the Outer Rim
    609
    Default d ring belt clip
    i would be interested in a couple of those, pm a link please if you find it xwing
    supertrogdor's Avatar
    Dec 2005
    553
    It would not be overly difficult to make one of those, a rather simple design such as that can be easily replicated, don't you think?
    simple to make, i made one for my vader belt.
    go to hardware store, with me so far?, look back where the nuts and bolts are. you should find a area where theres a display like setup with small pieces of sheet steel and aluminum, and so forth. small ones, like less than a foot square.
    grab the thickest aluminum sheet, ir stainaless, your choice, and lay out that pattern on it. draw one, design one, whatever, then cut it out, dremel, hacksaw, etc.... grind the edges up smooth and take off sharp points.
    then i used a pair of small visegrips, and made my tip bend, then using something to help curve it, easy cuz your plate will be thinner ther in that area where saber goes on and off, curve it over to form the loop.
    mark and drill mount holes where and however you want.
    and your done. i mad emine in 1 hour easy. piece of cake.
    Lan-Ed-Tul
    The Brotherhood Of The Sith
    SL 6208 501st legion & SLD
    TK-6208
    Proud member of the FSM!!
    Ryma Mara
    Guest
    Well I looked around on JA and found this link by accident actually. I was looking at belt puches and such.
    http://www.sdtradingco.com/hardware-...m#holsterclips
    Quick post you did.
    Yeah I seen that also on JA they said pritty much the same thing.
    Thanks for the info lan
    lol yeah i was quick on the draw, huh. lol
    i had made a pattern out of cardboard, thin stuff, like a cereal box or similar. drew my shape, cut it out and made the bends and curves. that way i could see how it would look once curved and such. when happy, traced and cut the puppy out.
    simple 1 hour or less job.
    your more than welcome, i love to share when i can.
    Lan-Ed-Tul
    TK-6208
    Aug 2006
    609
    after making graflex ears and inner ring sets im kinda fed up with metal shaping for the time being... call me lazy i guess lol
