Results 1 to 5 of 5
Thread: Blade Help
    Default Blade Help
    I purchased a thin walled white blade and its not bright enough with my rgb luxeon for prizm.What should i do?
    When you say "Not bright enough" what exactly do you mean? Is it barely glowing or is it just not as bright as you want? Did you wire this yourself or was it made by another company?
    In my experience there is no such thing as luck. Obi-Wan Kenobi
    is it just a white blade tube or did you put diffusion film and cellophane in it as well?
    I also have a transwhite thin blade and a tri rebel RGB led and mine is very bright. I would sugest a few wraps of cellophane inside to help with evenness but it should be fine. Make sure you have things wired up right.
    Post a pic so we can see what you mean
    i put in some cellophane and its much better.Thanks for the help
