Hello my fellow saber friends !
I can finally start my own adventure with the sabers and I am really excited. So lets start !
I will make 2 saber's in the beginning.. The first is wired with sound (the 2nd and more exp. one) and the other without ( stuntsaber)
In the following 2 Lists, I will post EVERYTHING I will buy for these 2 sabers.. Just to make sure I really don't need to buy again some stuff.. Because this shipping is already so painful !
1 Saber with NO sound :
Body:
Hilt style 2 drilled for a 16mm av switch 1x
LED blade holster style 4 1x
MHS choke style 1 short + Black Chrome powder coating 1x
MPS Pommel Style 1 1x
8-32 x .3" black thumb screw 2x or 8-32 x 1/2" black button head screw 2x / 8-32 x 1/2" button head screw 2x
Black machined button for covertec clip
MPS Clip x1
MPS Insert style 5 x1
Drill & Tap Hole x1
(1st Question here: I have no idea how many screws I need and which will fit in this saber. Also, if I take the thumb screw, I won't need the key , right ?)
LED
18deg Tri-Cree Lens x1
G/G/G Tri- Cree LED x1
Star thermal tape pad x1
Green Cree Part# XPEBGR-L1-0000-00F01
122 Minimum Luminous Flux @ 350mA
Forward Voltage @1000mA = 3.58v
(2nd question here: For the resistors I am not 100 % sure... I use this site to calculate it : http://led.linear1.org/1led.wiz
And the calculator said ( I wrote 3.7 v , 3.58 V and 1000mA in) that I will need a 2W 1 ohm res. Is that right ? And also just 1 since they are all green or 3?)
2W 1ohm resistor x1 (x3)
Heatsink module for 1" ID tubes with center hole x1
Internals
26 gauge wire Red x2
26 gauge wire Black x2
" "White x2
" " orange x2
18650 single Cell Holder x1
9" Electronics shield for 1.25" ID tubes x1
16mm AV Latching Green Ring Switch long x1/ Guarded Latching Switch x1
Brezel for iluminated switches x1
(3rd question : I know the momentary is better for the sound sabers, but also for the stunt sabers?)
MHS speaker V6 - For 28mm Speakers ( I just want to place the battery and stuff there.. So it's not just hanging around in the hilt) x1
For the battery I'm going to buy from a local store or amazon since they can't ship batteries... It will be the Panasonic Akku 2x NCR18650B 3,7V 3400mAh (http://www.amazon.de/gp/product/B00A...f_rd_i=desktop) (4th question here: Will this battery work for this setup?)
Blade
So.. I heard that this blades are one of the brightest (for dueling and cosplaying/display) I think I might get this from VV... (Note : I hope it's okay to post something from other sites... If not pls let me know so I can remove them..)
Vader's Vault Dual Diffused Blade 1" Dia. x1
VV Blade Dust caps x1
VV Blade plug x1 (I hope the blade and the plug will fit in.. )
2nd Saber WITH sound :
Body:
My second saber will have a Sabeforge hilt.. namely the Epoch ( I hope everything will fit in.. I think it's an 1.125" ID (http://saberforge.com/elite-sabers/e...epoch-initiate)
8-32 x .3" black thumb screw 2x or 8-32 x 1/2" black button head screw 2x / 8-32 x 1/2" button head screw 2x (I have no idea if they put screws in or not.. I assume they won't so I buy them just to be sure)
(5th question here: Does anybody what AUX switches mean ? Is it just a normal switch like the one I ordered for the 1st saber ? )
LED
R/R/W Tri- Cree LED x1
Red Cree Part# XPEBRD-L1-0000-00901
80.6 Minimum Luminous Flux @ 350mA
Forward Voltage @1000mA = 2.59v
White Cree Part# XPEBWT-L1-0000-00F51
266 Minimum Luminous Flux @ 1000mA
Forward Voltage @1000mA = 3.15v
(Same question here.. not sure which resistor I will need... So the calc said for the red LED's I need 1.2W 1.2 ohm (3.7/2.59/1000mA) and for the white LED (3.7/2.59/1000mA) 2W 1ohm res.)
1ohm 2W resistor x1
1.2 ohm 5W resistor x1 (x2 if both need one)
Internals
" "White x2
" " orange x2
Super Lube x1
12mm AV Momentary Red Ring Switch x1
MHS speaker V6 - For 28mm Speakers x1
For the battery I'm going to buy from a local store or amazon since they can't ship batteries... It will be the 18650 Kabel Li-Ion Samsung ICR30F 3.7 V 3000 mAh (6th question here: Will this battery work for this setup?)
(http://www.conrad.ch/ce/de/product/1...f=searchDetail)
Nano Biscotte Sound Module V3 x1
2W 28 mm Bass Speaker x1
NB v3 MWS Header and WIring Harness x1
Switchcraft 2.1 mm Power Jack x1
Kill key x1
Blade
So.. I heard that this blades are one of the brightest (for dueling and cosplaying/show room) I think I might get this from VV... (Note : I hope it's okay to post something from other sites... If not pls let me know so I can remove them..)
So there it is... It's a big list and I really hope I did not forget something.
I appreciate all kind of answers and wish you a nice day!
MBTFWY...A
