I'm planning on using a 4" Double female threaded connector: http://www.thecustomsabershop.com/4-...ctor-P123.aspx connected to a 4" Deep fluted double female threaded connector: http://www.thecustomsabershop.com/4-...ctor-P631.aspx.
In my desired layout, I will need a recharge port and part of a PLI cutout in the thread area. I was thinking the answer would be to solder a Gender Changer: http://www.thecustomsabershop.com/Ge...nger-P132.aspx to the 4" Double female threaded connector would be the solution, effectively making it a female/male piece.
However, in the description for the Gender Changer, it states that it should NOT be used in a high stress area of your hilt. This joint will be at the back end of my primary hand, almost between primary and off hand. I do want it heavy battle worthy. Is this a problem?
Or, is this the answer a Double ended male threaded connector style 1: http://www.thecustomsabershop.com/Do...le-1-P127.aspx and suck up/deal with the added 1/4 inch to the length?
Should I request a custom piece? Is there another option? Thanks in advance, MTFBWY.
