I still need to take it apart and apply some sort of finish. The Tri-lux setup that ace made fits perfectly inside the basic MHS tubes (not ribbed etc..). All I had to do was make a adapter to lock it in place like the regular MHS setup uses. It uses 8AAA in order to provide enough voltage. The sound is ran off of 4 of the batterys and switchs the LED's on via a relay. This setup is using 3 3watt led's so I am sure k2's would be even nicer.
