most of them here are, the cheap ones anyhow.Originally Posted by elrond.406
BLUE 3- Ready
Well this one was also a carpet shapoo-er.
Thanks for the compliment, but really that saber is way too light and narrow in real life. Still, seeing as I built it just to see if I could, and long before I discovered here and found out about luxeons and such, I guess it's not too bad.
I wonder what erv uses for his chromed tubes. I'll most likely be buying from Tim when I eventually build my own saber, so I guess adding a sink tube won't be too much extra. If only he had an outlet in the uk...
I thought he said something about vaccum cleaner hose. I'm not sure exactly but I know he mentioned it. I beleive he machines his stuff or has it done.
BLUE 3- Ready
it shampoos the carpet...duh
Think he was refering to spelling there, fetcher...
Dang, I can't beleive I futzed that one up.
It's been answed by now. As everyone says: plastic!Originally Posted by darthdan
I've beenl ooking round for alternatives, but the other thing to consider is that everything is in metric sizes. As I said, I'm looking at extruded aluminium as weight will be a factor for me. I want to keep the centre sections as light as possible so there's proportionately more weight towards the end.
Question: What Thickness (in mm if poss!) are the MHS hilt walls? I'm guessing that 2 mm would be a good thickness but that's based only on me going "ummmmmm...." and staring at the ceiling! I need as thin as possible to be structuarally sound and have enough for the screws to bite into.
I may have to see if I can try a few different thicknesses and test to destruction!!!!
Originally Posted by Bescherman
I like your way of thinking!
As you are going for double ended spinners, i would not be too worried about how much the hilt weighs. Balance would seem to be far more important, from what i can surmise. From the spinning i have done with the single and double sabers that i have made, the single is more cumbersome, but that is due mainly to the balance. The double saber i have the same amount of crud inside both halves of the hilt, and it spins just dandy, i don't get tired out from it like i did with my single saber before i made adjustments with it to achieve better balance.
