Hi all.
Doing a NB3 install, tri cree GGW, recharge. I'm not getting anything when soldered with minimum connections. Just bench testing at this point, and nothing.
battery ( charged full )
speaker, 2 different ones
switch, again different ones to rule that out
I am getting 3.8v from the battery leads, and from the NB pads when they are soldered on.
Tested recharge port and battery connections with a multimeter, seems normal. pulling the kill key results in...nothing. Nothing else is soldered on ( switch led etc )
Formatted and reloaded 2 different sd cards and 2 speakers.
Hit the pads with a 3v battery pack I use for testing led's, nothing. Which leads me to think my 18650 is fine.
Checked for bridging or any damage with a magnifier, there's none that I see. I've done several of these types of install now, including PC and CF, this one just has me a bit frustrated.
Edit: And I never solder with the sd card in =)
Thanks
-Darkmatter73
