Hello there!
so this will be my first try and i would be glad if some of the expert out here could have a look at it if this is ever going to live!
It's going to be a green lightsaber with sound
LED electronics:
Green/Green/White Cree XP-E2 CopperNova
Star thermal tape pad
MHS Heat Sink V4 (Flat Style) OR MHS Heat Sink V3
18deg Tri-Rebel/Cree Star Lens
.5ohm 3w resistor
battery and sound:
MHS speaker mount V6 - For 28mm Speakers
18650 Single Cell Holder
Nano Biscotte Sound Module V3
2W 28mm Bass Speaker
9" Electronics shield for 1.25" ID tubes
1/16" Heatshrink tubing
1/8" Adhesive lined heatshrink tubing
hilt and switch:
MHSV1 Blade Holder Style 27
Hilt Style 1 (7" Double female threaded connector) + Machine 16mm AV switch hole
MPS Pommel style 4
MPS Clip
Brass MPS Insert style 6
MHS choke style 2
16mm Anti Vandal Short Momentary Green Ring Switch
Brass bezel for illuminated switches
Drill & Tap Hole (8-32) "service" for retention screw
3/4" D-Ring + D-ring belt mount
8-32 x 3/8" Stainless Steel thumb screw
at home i have: sodering pen, dremel, wire cutter. I dont have anything to drill holes so i hope i got everything regarding drilling.
i am not sure with the choke and heatsink, which would be best? i dont think the bulky one will fit but maybe i can dremel it down?
with the blades i havent decided yet. can i buy one form vaders vault and it will fit?
here is a small render from the MHS editor:
