Hey all,
First of all I'd glady accept a link to a tutorial for the following.
2nd If you have any experience with the following I'd appreciate you sharing your insight.
I need help trying to wrap my head around this build. Completely overwhelmed just trying to figure out the right switch. Skipping to the next hurdle; can I wire 2 LEDs, with FOC and sound to a 18650 cell or will I need to use 2 18650s or 2 14500s?
1 Nano Biscotte v3
1 Hilt
1 momentary av switch with red led
2 custom Tri-Cree LEDs with FOC (royal blue, green, white-foc ) Can the colors of each die be modified using the NB?
values here (http://www.thecustomsabershop.com/Cu...LED-P1035.aspx)
1 2w bass speaker
? battery or batteries
I dont even know how to ask this;
for example: If I want a cyan with white foc for each end of the hilt, how do I get the color cyan? resistors to each die on each led? NB options? Do the dies for the main blade color have to be identical? (both the same value blue)
What will be the power requirement for these 2 leds in these colors?
At what point do I use a buckpuck?
Thank you for your time.
