Results 1 to 3 of 3
Thread: Diameter of 12mm AV switch and switch bezel
    Default Diameter of 12mm AV switch and switch bezel
    In planning my shroud, I have a question to ask: Can anyone tell me the precise diameter of the 12mm AV switch bezel or the 12mm switch itself at its widest point? I've realized the threading is 12mm, but the cap at the end where the button sits is larger, and I'd like to plan for that.
    In case anyone needs the answer to this question, from the horse's mouth: The bezel would be the size of the switch so roughly .47" ID x .544" OD
    Of course, because the bezel is meant to be flush to the button. Such a simple answer.
