I know for previous versions of the nano biscotte a pex hack was required but apparently, the v3 already has a pex. So what I don't know is how to use the pex that is installed and If I have to do any hack.
Try reading the Nano Biscotte v3 users manual.
The V3's PEx is for Flash on Clash. It has nothing to do with the main channel.
"12w" LED tells us almost nothing about the LED you're using. If it's from SF, it's likely that you will have no luck here as we usually don't deal with their products.
If this is your first go with an LED/or board of any kind, I may suggest something a little more straigt forward
http://www.thecustomsabershop.com/Lu...Star-P777.aspx
or
http://www.thecustomsabershop.com/Bl...ova-P1013.aspx
as an example.
If you wish to do color mixing
http://www.thecustomsabershop.com/Cu...LED-P1035.aspx
there's a video here in the forum by Madcow
http://forums.thecustomsabershop.com...rs-Made-Simple
NanoRex is correct the built in PEX is for the FOC. One of the suggested LED's above may get you started. As well as the look at the video.
