So being the first, and most likely, only sabre I will build I want a really nice one. So I know I am probably being ambitious for a newb, but why not make the best I can. That said, I have no clue what I am doing. Below is my first draft at a parts list for a red sabre, with red AV switch, and brass accents on hilt.
I am still reading up on how this all work. But can someone take a look and let me know if I am even close with my parts list? Any suggestions or direction would be much appreciated.
This is he body shape I want to try for. I cant get the Java app to put the switch activation box in the right spot, but id like it just under the choke.
Body
MHSV1 Blade Holder Style 23
Hilt Style 5 (7" Fluted double female threaded connector)
?Machine recessed 16mm AV switch hole
MPS Pommel style 8
MPS Clip
Ribbed / Choke Combo
Trim Ring 2
Brass Activation box style 2
Brass MPS Insert style 6
8-32 x .3" Gold thumb screw
Internals
18deg Tri-Rebel/Cree Star Lens
Star thermal tape pad
12mm Anti Vandal Momentary Red Ring Switch
Custom Tri-Cree LED
?White Cree Die
?Red Cree Die
?Red Orange Cree Die
Red LED indicator (for glow out pommel brass panel)
Crystal Focus Sound Module V7.5
Acrylic Chassis Disc for PC 2.0 and 14500 side by side pack - S5 (Black) (will this work with the crystal focus module?)
7.4v Li-ion 800mAh 14500 Battery Pack
Blade
1" Thick walled Trans Red PolyC 40" long
Bullet shaped tip for 1" thick walled blades
Again, any help will be greatly appreciated.
Brian
