How much acetate? That's what Ultra uses and it works really well. I believe he uses between 3 and 5 feet of the stuff.Originally Posted by mikeclem
Either way if you have some coming from Erv you should do fine then. Double wrap does make a difference. It depends on how defined you want the core. Since you have acetate I'd keep it around and play with it once you get Erv's.
Corbin's kind plays up that it comes from the bottom. If you add about two wraps of that acetate it should look a lot like the completed blades Erv sells.
