Results 1 to 7 of 7
Thread: Batteries Li-on
    Default Batteries Li-on
    Hi I'm new to building light sabers, My question is if I connect two 3.7v Li-on batteries in parallel do I only use one 3.7v PCB or two.
    Thanks in advance.
    Each battery should really have its own pcb. Most 3.7v pcb's are only meant for a single cell and would be unable to balance e the charge between the two.
    Thanks for your answer. So if I installed two separate batteries with PCB's, to extend run time in the hilt, would it be possible to charge them simultaneously from the recharge port.
    I haven't tried that myself, but it should be possible. Each cell's pcb will cut off the charger once the correct threshold has been reached.
    Thanks for that. I'll set up a bench test
    Make sure you get 2 new cells from the same batch/box if possible. You want these cells to stay matched as it will make charging and discharging much more predictable and safe.
    Quote Originally Posted by bambua View Post
    I totally agree, its very important if your using two LI-ions. "Mating" the pair, as I call it.. Always use the same brand for a "mated" pair.
    Charge each one at the same rate (I.E if your charger has a low setting, both should be charged on the same setting). Mark them, and label them.
    A great investment is a charger that can "read" battteries as they charge, with a digital display. It tells you if your battery seller is really giving you "new" batteries.. Its saved me money and time dealing with batteries sold as a "Pair" that were actually used separately.
    Also, look up the basics of handling, storing, and using Li-ion cells if your new to using them. Safety first.
