Results 1 to 5 of 5
Thread: Need assiatnce in Resistance Computation
    Default Need assiatnce in Resistance Computation
    Can some one please help me double check my computation for the RESISTOR.
    I'm planning to make a rebuild, instead of having one LED I'll be using Tri Cree XP-E2 CopperNova - Blue/Blue/White for FoC effect. I'm thinking of putting resistors for each of the LEDs.
    Main Power source is 7.4v Li-ion 2600mAh 18650
    Tri-Cree Details:
    Blue Cree Part# XPEBBL-L1-0000-00301
    45.7 Minimum Luminous Flux @ 350mA
    Forward Voltage @1000mA = 3.47v
    White Cree Part# XPEBWT-L1-0000-00F51
    266 Minimum Luminous Flux @ 1000mA
    Forward Voltage @1000mA = 3.15v
    Computation:
    BLUE LED:
    Power:7.4v - 3.47v = 3.93v
    Resistor: 3.93v / 350mA = 11.22 ohm with 1.37 watts
    WHITE LED:
    Power: 7.4v - 3.15v = 4.25v
    Resistor: 4.25v / 1000mA = 4.25ohm with 4.25 watts
    I was also wondering if I would just put 1 resistor (more powerful) for the 2 BLUE LEDs? I'm open to better suggestions, thank you!
    May 2015
    United States
    1,756
    2
    Quote Originally Posted by spooky3369 View Post
    Tri-Cree Details:
    Computation:
    BLUE LED:
    WHITE LED:
    Your calculation for the blue is wrong. You're using the test current from the luminous flux measurement. While you could do this, your led wouldn't be very bright. You need to use the forward voltage test current. I've highlighted the lines of importance above.
    It is recommended to use one resistor per each led.
    What I did here is subtract power source voltage (7.4v) to the forward voltage of the LED (3.47v for the blue)
    May 2015
    United States
    1,756
    2
    Yes, but for the second part of the calculation you used 350mA rather than 1000mA.
    oh, i see what you mean. thanks!
