Originally Posted by
Silver Serpent
I don't see any batteries, so I'm assuming you're getting them elsewhere. I also see just one resistor. You're going to want one for each of your LED dice.
Location of switch hole is up to you, though I'd advise against having it in threaded sections of the saber. Get it someplace comfortable to press when you're holding the saber. Make a mockup out of cardboard and see where your fingers lie while you're holding it.
I typically use an 8-32 screw for blade retention. Sometimes I use a set screw if I want a clean look, other times I use a thumbscrew for ease of use. It's up to you really. You could also get one of each, since they're easy enough to swap out.
