Results 1 to 4 of 4
Thread: LED String Resistor help!!
    Default LED String Resistor help!!
    Hey guys so im building my LED string, its 10 segments of 10 LED's.... So 100 of them..they are wired in Parallel i used the LED Calculator and it says i need a 1ohm 4 watt capable resistor. Is that correct? if it is can i use a 1 ohm 10 watt resistor? my local radio shack doesn't have the 4 watt one
    LED Specs: 5mm, 3.2-3.4v, 20mA
    Battery: 3.7v Lithium Ion 18650
    Thanks
    That LED calculator always rounds up to at least 1ohm but you don't need more than .5ohm. (even that is more than you need) 4 watts is right, and 10 watts would be fine as long as it fits in your build.
    ERUDITION
    Quote Originally Posted by Miraluka View Post
    Sweet, thanks! also this is such a noob question but ive heard multiple answers to this and im a little confused.. Does the Resistor go on the Positive side or negative side cause ive been told both so idk which to do.
    Resistors can go on either side.
    Exception: If you're using a DynaOhm resistor for an accent LED, it must go on the positive side.
